dyoung14
Is getting worn out
So the other morning i made it a mile up the road and my truck dies, ok the electric pump was making horrible noise and i had no fuel pressure, so i since then swapped the electirc for a mechanical that is brand new, it still acts the same now like it has no fuel pressure and it will run if i pull it off but you have to keep it on the floor the hole time, some times it will rev up sometimes it will run good, and i will drive it down the road but it has no power and you pretty much got to keep the pedal against the floor to hold speed, so i changed the new fuel pump with a factory one of another engine, and it still does the same thing,
Now the reason the electric pump died was i poured some waste motor oil in it that i thought i had filtered but i didnt filter it, i know i should have filtered it again just to be sure but i didnt
anyway after i found out it had junk in it i dropped the tank and got it all out blowed it out of all the lines and changed fuel fiilter and put 45 dollars of new diesel in it, but i still can figue out why my truck wont run!
Is there a certain way to installing the mechanical fuel pump?
![Cussing -cuss -cuss](/styles/default/xenforo/smilies/cussing.gif)
