hotford
I have a 85 F350 6.9 with 180k on it non-turbo. I got it the way it sits. It has a veggie conversion on it and has been one there for 20k. A while back it got hot so I parked it and looking into the cooling system. I replaced the water pump, rad, stat, and all fluids. Not hot now, but blowing smoke, white smoke. So I figured heads or head gaskets. I had my buddy thats good with these and he tore it down.
I looked at it last night. Was very apparent that the head gasket was blown. Also the pushrods and the rockers show a great bit of wear and tear. The push rods are almost worn through. Also the valves are worn on the rocker side and they are starting to get pulled into the seats of the heads. The block looks good, cyclinder walls look good. This motor has never been pulled apart.
The reason I got the truck is to pull my 25ft goose and 6k Jeep around to go wheeling. I know its not going to be a power house. I got $2,500 in it now. I want to fix it back to be reliabe. I plan to get reman heads, new push rods, rockers, arp head bolts, felpro gaskets, new injectors, new glow plugs, new injector lines, injector o-rings and caps. I plan on running the veggie oil.
I want this truck to be very reliable, so I'm not tring to race up the road or hook to the sled every weekend. If there are somethings that I can do while I'm in ther please let me know. I'm not to big in the diesel world, I can build ya a rock buggy from the ground up, or throw together a mean small block. So I'm asking for the secert special formula to unleash the beast in these old trucks. Can there be some porting going on, better gaskets to go with, stronger rockers and pushrods, which head bolts? Also should I replace the injection pump, have it rebuilt, or just leave it and do it later if needed? It was running pretty good before.
Thanks for the help---I need it.
Chris
Chris
