Ok going full Dr house on this *****
Oledirtypearl86
Whitehall MT
I have a 97 f350with a 7,3 and a 5 speed it has a intermittent cut out and a full shutdown when pulling I can't het it to do it with the scanner data logging in the like 13th mech to have it I can't find anything any ideas
Clb
Another old truck
nannyfornia
Bad connection?
Sounds gee'lectric...
Bill gates?
( phawkinputers)
For sale sign?
Aint there a way to reset those puters?
gnathv
Athens, Al
Does it ever cause a check engine light and have you checked for stored codes?
  • Like
Reactions: Clb
lotzagoodstuff
Carmel, IN
Any chance your radio goes dead when this happens? If it does you could change the ignition switch. Not the key switch, the one down by the floor that looks like a rectangular white box.
Have you pulled the IDM and opened it up to see if there's any sign of water in it?
After that, you are on for the "run it with Forscan/monitor until it does something you can see".
Good luck. Electrical problems are tough.
Oledirtypearl86
Whitehall MT
So gave it a good looking at and ran it today I still couldn't get it to crap out on me but so far everyone else has done icp, ipr, crank , Under valve cover wiring harnesses , 2 sets of injectors and on and on and on tomorrow I'll pull the idm and give it a look and start ohm the harnesses I did notice in the fuel filter looked like a small glob it was hard to see as it was getting late and kids were hungry but so far I hope it's not a electrical issue to crazy but I appreciate the ideas
greenskeeper
PA
Any codes?
When it shuts off does the WTS light illuminate?
If it does this would indicate a power issue.
CPS ?
Oledirtypearl86
Whitehall MT
Yeah like 4th cps all napa crap and icant get it to stutter or shut down tomorrow ihave all day for it nothing out of the ordinary no codes of course I didn't take it loaded down a dirt road first
Randy Bush
Great Falls, Mt
After market chip in it? Mine was doing strange like shutting off going down the road ended up being a bad chip , put things bac to stock no more problems. Hate problems like that.
Nanohawk
