oil rail plugs
94f450sd
somewhere,ma
Flex head ratchet.I remove the turbo to make life easier.
Ive heard of dealers using a hole saw to cut a hole and go through the firewall.
flathead jack
okla,city,ok usa
one shop told me i had to pull down pipe and if i couldnt break it loose id have to pull the motor he told me 300.00 and if he pulled it 1600 ever heard of that
94f450sd
somewhere,ma
take the down pipe off the turbo and it should move enough to get at the plug.motor doesn't have to come out.if the pipe is in the way still, pull the turbo.be a good idea to replace the turbo pedestal orings, up pipe donuts, fix the leaky ebpv actuator.
1300 to pull the motor?300 if he doesn't pull the motor? Is this guy on crack? Cuz his prices sure are high.
