When I say power I'm referring to electrical.
We'll I went out to bleed the lines and the truck won't turn over, crank or anything. When I turn the key the glow plug cycles then when I go to crank nothing. All the dash lights light up when I go to start but no crank. If I arc the solinoid it cranks, does it mean the ignition cylinder is bad? I've read a few things about the actuator rod but I took the plastic sleeve off of the steering columnand the rod moves when I turn the key but the engine doesn't crankGlad you got it worked out. I bet the starter will turn over now too.
Good luck!
No my test light doesn't illuminate when the key gets turned over. My test light is one without a battery. I hook it to the positive side and touch the small stud on the solinoid and nothing. If it matters the starter solinoid was from my 1994 7 3 idi n/a.does your test light,illuminate when you test the small ignition terminal on the relay,when you turn the key forward to start? if so,tap the relay lightly.should unstick it and fire right up.
The relay on the fender apron(glow plug )clicks but the relay on the fender wall(starter) doesn't click. When I jump it from the battery to the small post nothing happens.Does your fender relay click when you turn the key to start or not? If you don't hear a traditional relay click that fender relay may have died during this.
You could always rule out something ignition related by leaving the key to on, but instead of jumping the two big posts with a screwdriver connecting battery positive to starter positive, jump battery positive to the smaller post with the little rubber connector (that comes from the ignition), if the truck turns over and starts something is up from the ignition. If it doesn't start like that, but jumping the big posts together (battery positive to starter positive) then your relay is dead.
Make sure your in neutral and all that good stuff while doing this, would never be fun to solve the problem and watch as the truck drives itself away.
