smoking89IDI
Well I just changed the oil in the truck, had auto-rx in it and that has done great so far my problem lies with what was in the filter. I cut open my last filter (before auto rx and using a quart every 1100 miles) and it had some small pieces of brass, steel and aluminum in it, this time I had NO brass and lots more bits of steel and very little aluminium, these pieces are very small but you can count them individually with the naked eye, in fact a couple were actually large enough that you could grab them (still smaller than a grain of salt though), I just hope that this truck isn't about to blow up on me, that would suck!! I am rather confused though as to where this metal is coming from, the engine runs great and only burned 2 quarts of oil in 3,200 miles (1 1/4 low at this change, never added oil since the oil change but did add two bottles of auto rx for a total of .75 quarts extra) with no blue smoke at the exhaust, is it possibly just a thrust bearing going bad (or gone) which is why I had the brass and now I don't? Or was all the metal in the sludge liquified and sent to the filter and it is just old debris? Any help on this is much appreciated thanks guys!!! BTW alot more oil leaks out from my cracked plastic CDR tube to the intake housing for the turbo than it burns I think, makes the driver side spring nice and quiet .
