to keep this going, also using a 99 24v and no start condition hot. have to spray it to start.
new vp44, verified fuel pressure, new fuel/air filter fixed all the boost leaks runs great, new TPS
set at .6 volt and 3.78 wot and turn it of after a 10/20 mile commute no restart on 9 out of ten tries.
The hell micro-soft got into the puter and sprinkled bugs into the program jeezusfknchrist.
truck stop starting by the key but the key has to be turned to the run position to start
and under the hood there is a push button switch for starter wired into the batt to starter switch wire.
starts fine with starting fluid. The air intake heater is there but have to rewire it up. that wont help start a hot diesel will it? just put in a brand new $1400 vp44 and it now has power and starts fine, but will not start hot with out spray? ***? My 7.3 int don't punish me like this fine fine dodge cummings hybrid does. the dash is awesome on the dodge! like hiroshima went off.
codes are 4 PO382 PO380 P1693 and transfer pump circuit out of range.
why wont this hunk of iron behave like one?
