Boy, it's been a long week. Snow removal kicked my butt! Anyway, thanks to Mel and Jasper's advice I was able to get the truck started and home on Tuesday... I cracked the injector lines and waited for wetness, retightened, and tried to start - nothing. Didn't even attempt to turn over! Despite the gpr cycling properly, I was getting a wisp of smoke and a whining sound as if from excessive heat so I removed all wires and the heat sink and cleaned connections. I then cleaned the connections on the starter relay as well. I found a broken bolt on holding the gpr that comes up from the controller. It had the ground wire on it and I think may have been my issue with that. Put it under a nut at the valve cover. I also double checked all the return line work I did. Plugged in the block heater with my Pathfinder cigar lighter and an adapter. Glowed the plugs one more time and YES!!! Turned over, kept running, and got me home.
