No oil pressure, round two
Dieselcrawler
Professional wrench holder
Quakertown Pa
ok, follow up to my other post a few weeks ago. Finally got time to drop the pan and check the pump. Oil pump is perfectly fine. Even took it apart to look at the gears, not a single mark on them. Now in the pan I found these plastic pieces. Hard plastic, they have a radius to them the same as the quarter. I compared them to a new exhaust valve seal, no match. What else could they be from? I had the pan off this engine 4 weeks ago. Nothing was in it. I feel these are related to my no oil pressure issue. On the larg piece I can see ribs on the inside edge of it.
Hydro-idi
Lodi, California
That looks like bits & pieces to that plastic insert that joins the CDR valve tube to the valley pan grommet IMO.
Could be wrong :dunno
my guess is this has something to do with a past fuel pump coming apart. Or this was FOD from someone building this engine before you got it.
Thinking maybe your bypass is wedged open? Have you pulled the valve covers?if it’s not cdr related, I can’t think of anything else unless something literally got dropped in through the oil fill. I’ve never had a mechanical fuel pump apart. Anything plastic in it?
To get there it pretty much either had to start in the engine, get dropped in the oil fill. Dropped in the cdr hole or come from the fuel pump. Too big to come through the dipstick. Any other orifices to the oil you can think of?
Dieselcrawler
Quakertown Pa
I had it apart 4 weeks ago before I installed this engine. Resealed everything. Nothing was in the pan. We did swap oil coolers with a known good one, no change.
jwalterus
Made in America
Garrison, ND
Grab the input drive gear in one hand, and the internal pump gear in the other, and see if they move on the shaft at all.
You shouldn't be able to move them at all by hand twisting opposite directions.
If you got a tiny one of those pieces into your pump just right, it could have jammed the internals of the pump, and made the shaft spin inside the gear.
I'm still betting it's the pump.
Dieselcrawler
Quakertown Pa
Ok let me rephrase it. I swapped the pump. I took the old pump completely apart. Locked gear in vice and with a large pipe wrench, tried to turn it. Nothing wrong with the pump, not even a single score mark on the gears
jwalterus
Made in America
Garrison, ND
Those pieces must be blocking the flow in your primary oil passages, that's all I can think of.
I wonder if you could go from the pump mounting and check with a borescope........
If it's limiting flow directly after the pump, you won't flow enough oil to build pressure, even though your pump is working.
UNLESS: could those pieces have somehow been able to cover enough of the pickup screen to keep you from getting enough oil? I don't see how myself......
Dieselcrawler
Quakertown Pa
It wasn't there 4 weeks ago when I resealed the pan. And it isn't threaded, I looked close at that part. Its ribbed
Shadetreemechanic
Monteagle, TN
Did the new oil pump fix the issue, or are you still without oil pressure?
F350camper
BOOST!
Any chance at all in the world that those fragments aren't plastic? Maybe light a piece of it up with a torch and see what happens?
placidoert
