No crank
BlkSmkCstms
Rock Island TN.
Its been a little while since I've worked on one of these but if I remember correctly there is a short section of wire between the inner fender and the passenger side battery that is susceptible to corrosion from the battery. Its about a 4 gauge wire, if I remember correctly it supplies power to the run system.
On a side note, I never use a multimeter for this kind of thing. Their priceless for certain things but not necessary for a basic troubleshooting. Get yourself a test light from NAPA. You don't need the logic one, just a simple $10 one will do. And remember to double check the ground to it before you condemn anything. There are plenty of videos on YouTube on how to use them.
Farmer Rock
Glen Rock,PA
I talked with the OP yesterday,he said it works now.It seems one of the stupid fusible links had a bad connection inside,and when he shook it,the truck started right up,so he is replacing the fusible links with inline fuses,which are obviously a lot nicer.
Rock
