ihatelaramie
About a month ago I bought an 86 F250. It shows 96000 on the odometer, and I think that might be it, considering the shape of the rest of the truck. Within the last week or two it has started to make this ticking, almost knocking sound at anything above an idle. It sounds a little bit like giving an anvil the slightest tap with a ball peen hammer. You can't hear it outside the truck at all, only from in the cab, and it sounds like it's toward the driver's side. The sound very closely coincides with the injector noise. The truck has an aftermarket oil pressure gauge that shows about 50psi going down the highway, and 20psi+/- at a warm idle, and that has not changed since I bought the truck, though I have done an oil change since.
My question is, what could this sound be caused by? Could it just be an injector? Would a collapsed lifter make that sound? I'm hoping it's nothing major, cause I got rid of my 95 Powerstroke cause the problems were getting expensive.
