averagef250
My name is Dustin and I recently bought a 11K GVW 89 F-350 4x4 with a 7.3 non turbo, ZF5, 4.10 10.25 sterling with a detroit locker and an open 60 front. It has over 900,000 miles on the chassis used as a field maintenance truck for a large construction company. I bought the truck for $700 with it's ZF tranny stuck in reverse. I have several older Fords powered by Cummins engines, but none with a chassis like this one and the price was far too good to pass up.
I rebuilt a core ZF 5 speed I had in the shop and swapped it out on the ground since the truck is too heavy and long for my rack. It runs and drives fairly well now and has respectable power. I have the maintenance history for the truck, but it is poorly written and very vague. The truck has seen 3 reman 7.3 engines, two 1356 transfer cases and is on it's second complete body and 5th pair of doors. It appears it has it's original untouched sterling rear sans the detroit install and the ZF was untouched until the final failure that deamed the truck unworthy of repair.
I have no idea how many miles are on the current 7.3 and I'm a little curious what I can check to determine it's condition? The oil's black, the engine leaks a small amount, the coolant looks very good and the level is always at the top. The two unusual things I noticed is it seams there's a lot of oil residue in the intake manifold. It appears to me these engine's route crankcase gasses into the intake, is oily crap buildup in the intake normal for these? The engine also is not easy to start cold. Battery cables are 4/0 and in nice shape, batteries are good and fully charged. I have to plug/crank plug/crank up to 3 times to light it off. Is there a guide somewhere for glowplug system troubleshooting for these?
I'm very familiar with mechanical 3.9 and 5.9 Cummins engines, what they should make for power, what they run like and how to get much more than factory power from them. This is the first IDI I've touched with the intent of maintaining and driving it as opposed to pulling it out and dropping in a Cummins. I would like to get more from this engine if there are cheap easy tweaks that can be done. I plan to tow at the legal limit with this truck if the engine will do it, so any advice on what, if any mods can be done for that use would be appreciated.
Thanks for any help!
