A few weeks ago the fully warm engine quit just a couple minutes after switchover to WVO . I finally removed the bad IP from the engine using instructions here - http://oilburners.net/brian/idi/FuelInjectionServicing.htm ) the 12 point bolts were very difficult to remove almost as it they were stripped. . The shaft was in one piece but turned rough rotating it clockwise and it would lock up clockwise not allowing full rotation . I could not find decent price on an IP from the 2 local rebuilders because the condition of core so I wound up purchasing a Borg Warner Remanufactured IP for $550 from one of the chain auto parts stores . I installed it (has to use new bolts to fasten pump to gear) and lined up the timing marks but could not get the vehicle to start. I wouldn't think the little residual WVO in the injectors would keep it from starting ( I tried a little WD40 and ether too ) , I think that I might have got a bad pump (from a mass rebuilder ). I removed the remaned BW pump and took it back for a refund and need some advice on where to go from here before I start over again . -
Thanks
http://www.oilburners.net/forums/showthread.php?t=19770&highlight=borg+warner
Thanks
