SlippyRider
Is your timing 180 degrees out? It's easy to do and would cause the exact symptoms you're describing. You say it starts with ether? Is it running ******, with very low power?
Also, I see comments suggesting these engines won't fire without glow plugs. Nonsense.
A block heater and cranking the engine will fire a properly timed engine with a reasonable amount of compression.
Maybe your pump is 180° out of time.
