New here with a question
gmikell
Lexington, S.C.
Can anyone tell me or show a picture of the puller required to pull the pulley from the power steering pump on a 93 F350 idi non turbo? Thanks
Thats the one you need. If you try to remove the pulley from the vacuum pump or power steering pump without this simple puller you will ruin it and then have a tuff time finding a replacement. At the bottom of the page is a cheaper tool at $14.00 but I don't know if it will fit what you want .. Usually these have two differant sizes on the tool. When you get one you will see the differance. That tool grabs around the ring right at the shaft area of the pump. Not way out of the belt area.
gmikell
Lexington, S.C.
thanks to both you guys! That was exactly what I needed to see. You guys are the best. Thanks again, Gene
Vincent
