Doug Iwill look for motor mt pix. I used the 7.3E350 mts. I removed the stock motor frame stands and fabbed up new ones out of 1/4x 4" flat iron and drilled them to fit the stock GM frame holes and the 7.3 motor mts. Watch out for steering draglink to pan clearance! These motors are pretty tall compared to a Chev. Lay a 2x4 across the fender tops to check your hood clearance, found that out the hard way.Do you have any pics of what you did with your motor mounts? Looks like it will be fairly easy , but if you have anything to go off of I'd appreciate it.
YES I DID! and pretty poud of it too. Been watching the aux trans thread pretty close too. I have been playing with a simmilar idea only Ive been thinking about converting the front half of A NP203 into A divorced Aux trans. Flip the 203 around and you should have a direct/overcase with about a 2-1 over ratio. Shift 1 though 4 direct then shift 4through 8 in over drive.Did you build the truck? Did you see the recent discussion on aux transmissions? Your comments would be most welcome.
Thanks Gruss . Been thinking about painting her this winter, think I want to try a new color maybe all black.Al E that is a sharp looking truck The ol IDI looks right at home in between the fenders of that Chubby JK Nice ride, and emblem
Just thought you guys might like to check out my new grill emblemYou must be registered for see images[/URL][/IMG]
I didnt need the hood for clearance issues, she was a little hot under the collar so I put the cowel hood on for extra ventilation. My father inlaw made the emblem up on his CNC. So its a one off custom maybe you could find someone locally to do one for you. I dont see why you couldnt adapt the F350 plates all it takes is some creativity and maybe a little welding.
