BC4Lyphe
Hi everyone I just joined this forum to try and learn as much as I can about my new truck. Any tips, tricks or info is greatly appreciated.
I have a truck that I know very little about. Unfortunately its 5400 miles away and I wont be able to check specifics on the truck. My brother will be sending me pictures when he picks it up so I have to wait until that happens to get more info. What I do know is from the door sticker: VIN 2FTJW36M9RCA13544. WB:168" TYP-GVW: W361 BODY: G6D TRANS: E AXLE: C5 SPRINGS: T F. It says 9/93.
I gather it's the E4OD tranny? Is there a way to tell from the VIN if it's turbo or N/A? Also if it's 4x4 or dual tank? I know its a crew cab long bed.
The guy said the following:
Front wheel bearing wore thru and I'd need a new hub
PO converted it to run on WVO
Back two cylinders were completely full of water. Wouldnt turn at all
He put a new starter in
Not exactly sure which side or if he meant it chewed the the bearing race or the actual hub. If it is 4x4 does that mean it has the manual locking hubs? Does this truck have the D60 front and Sterling 10.25 rear axles?
What is involved with the "WVO conversion" Is it just new lines and filters? Usually 1 tank is WVO and 1 regular diesel correct?
He said the rods are fine since the starter never had the chance to wind up before hydrolocking. I guess thats good? Will the rings be toast? If I pull the glowplugs and get the water out then spray it down with WD40/diesel/motor oil and crank the motor by hand for a while will that be good enough? Then pressure test all 8 to see if theyre consistent?
I have a little experience with a very rough shape '88 IDI, Banks turbo, ZF5 speed single cab. In the spring I plan on working on this crew cab and getting it ready to tow 6000lbs 5400 miles. I read a few things about disc rear conversions. It seems a lot of problems are getting parts so there would be a parking brake. In the '88 we just use a line-lock so if I had a bracket machined to fit the axle tab and used the same 4 piston caliper and rotor as the front would that work?
