Neutral safety switch
Ole BlackBetty
Norman, Oklahoma
Tried adjustimg my safety switch today and thos is as close as it will get to line up.
the only way i know how to adjust the neutral saftey switch, is by pulling the connctor and jumping contacts
Think he's saying to bypass it completely. Lol
Looks like you might need to cut down those washers.
chris142
SoCal
Can you grind the edge down on that one washer? I always bypassed the neutral safety switch on my stuff.
Ole BlackBetty
Norman, Oklahoma
Went out and checked the washer situation. It is not the problem, the adjustment slots arw not long enough to get it to line up properly. As far as jumpping around the switch, i dont think thay is possible on an e4od automatic.
ifrythings
BC
If you truely have the trans in nuetral and it will not line up, more then likely you have a bent linkage inside the transmission that needs to be fixed first or you will never get that thing to shift right.
trackspeeder
Stone crusher.
North Branford. CT
Will the tranny shift through all gears manually.. If not drop the pan and check the manual lever
To set the sensor, you must place the tranny in neutral. Line up the index marks. Tighten bolts and your done.
Ole BlackBetty
Norman, Oklahoma
I checked manuaal shifting on the way home from work . Trans shifts into all gears manually , but is is in nuetral in the picture and it will not line up with the lines . And when i pull the bolts to line it up , the slots in switch are out of line with bolt holes. Anymore suggestions would by appreciated. I am getting a code 62 which my book says is neutral safety switch out of adjustment. I hate to go just buy a new switch unless it is needed
trackspeeder
Stone crusher.
North Branford. CT
It could be bent. Most of the time it a matter of pushing it back into position. By removing the pan you will see if the manual lever came out of position.
Cv axle
