Needed: FIPL / TPS bracket for IDI pump for my E4OD swap
FORDF250HDXLT
Maine & Oklahoma
in case nothing used pops up.so you can buy new if you want/needed;
Throttle Position Sensor: CX1448
Fuel Injection Pump Throttle Position Sensor Bracket: 9F878
Fuel Injection Pump Throttle Position Sensor Bracket Screw: 9F885
Fuel Injection Pump Throttle Position Sensor Bracket Locator Screw: 9F887
Fuel Injection Pump Throttle Position Sensor Screw: 9F883
Fuel Injection Pump Throttle Position Sensor Bracket Screw Washer: 9F888
source; fordparts.com
cpdenton
Truck needs paint.
Conway AR
I have a couple of them. With sensors. I also have the little tab that makes the connections.
I can set you up. I went from auto to manual on my truck, and have a parts motor.
Need wiring harness too?
Biggest problem is I am leaving tomorrow on vacation until next Friday.
Glad someone posted you need the drive tab thas connected to the throttle shaft end. BTW that connector MUST be installed correctly or the tps will break when you give the engine full throttle.
cpdenton
Truck needs paint.
Conway AR
All this can be yours. Make me an offer!
84TD
Virginia Beach, VA
Thanks cpdenton, a local guy hooked me up with one for 10 bucks. I will test the sensor on it and if it isnt right Ill PM you for a another used sensor.
cpdenton
Truck needs paint.
Conway AR
Glad you found what you needed! It probably would have cost 6 or 7 to ship mine to you. I am not sure how good the sensor I have is either.
Now, don't forget to keep us posted on how the swap is going.
cpdenton
Truck needs paint.
Conway AR
I still have all that is in this picture. If you need it, it's yours for 40 shipped sound good?
