Need wiring diagrams for 1991 f250 7.3idi with the e4od transmission!
jonleroy2506
Spirit Lake ID
Hey all
I am still trying to trace an electrical issue in my truck but I don't know what to do next without a wiring diagram. I cannot find one on the interwebs anywhere. I need to confirm that the wire coming out of the load side of fuse 18 splices into two wires that run into the two plugs that connect to the dashboard cluster. I am sure at this point that there is a direct short circuit between the fuse panel and my cluster, but I can't isolate the wire from that fuse as it dissapears into the depths of the dashboard. If I can't find a diagram somewhere, I will have to take the dash out in order to get to the wiring, which I may end up doing anyways, I would just rather not if at all possible. Any leads on where I can find a wiring diagram would be greatly appreciated
