LCAM-01XA
How does your shifter connect to the transfer case, do you have a Z-linkage with a flat bar connecting the shifter and the transfer case levers? Or does the transfer case have a fork-like lever on it sticking straight forward that meshes directly with the shifter lever (which sticks straight back) thru a single plastic roller/bushing?
The NP208 setup is the Z-linkage style, that shifter generally does not care if the case is NP208 or BW1356 or even a later BW4407. It also does not care how many bosses the adapter housing has, as it only needs one. If you have Z-linkage you should be able to use either adapter housing.
The fork-like mesh I've only seen with BW1345s and they all had the gated plate. Those require the 2-boss adapter housing.
Can you post a picture of the rear of your transfer case?
