Compu Doc
My Carrier Transicold fuel pump arrived and I am looking to now get the other parts needed such as fittings and hose. What I want to do is remove the mechanical fuel pump and put a block off plate on. I also want to keep the steel line that runs from the lift pump to the fuel filter and I want to keep it fully intact. This means I will need a female fitting for the male part of the line that goes into the mechanical lift pump, Does anyone know what size fitting I should be looking for and where I can get one. I would prefer one with a barb so I can put a hose on it. If I mount the pump under the hood I can have this go to the electric pump but if I can't I can then take the rubber inlet line and hook it up to the fitting. This would make a loop from the lift pump inlet line to the outlet line that was on the lift pump. I'd like to keep it this way in case I have to go back to a mechanical pump if the electric pump failed and left me stuck all I would have to do is install the mechanical one back on.
I'd also like to know the sizes of the fittings I need for this pump as well as what hose size I should be buying.
