Need help with International tractor
brians
San Jose, CA
My International TD340 crawler just started stalling. It has an International 4 cylinder D166 diesel engine. it fires up fine then slowly loses rpm until it stalls. It runs great when you fire it up but after a minute it loses power.
I changed the fuel filter and checked the flow out of the tank (it's gravity feed). Removing the muffler doesn't help.
Any suggestions are appreciated.
Brian
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Hi Brian!
Have you taken a look at the governor assembly and made sure that everything's in adjustment? I've never dealt with one of these engines, but I saw a 6-71 that had a similar problem...ended up needing to replace the entire governor assembly cookoo
Just a thought...best of luck with it ;Sweet
RLDSL
Diesel fuel abuser
Arkansas
Tank vent is most likely plugged run into this many times . If it has a separate tank vent hose, it most likely has mud daubbers filled it up and clogged it, if no hose, then it has a vented cap that is supposed to let air in as the fuel goes down but its not and its causing a vacuum. Try leaving the cap off and see what happens, if it keeps running youve found the culpret and get a new cap
jchellen2
