Need advice on mechanic
rpmfan43
Have 2004 6.0 F-350 need to have oil cooler and egr delete put on. As well as having the head gaskets checked. I live south of LaCrosse, Wisconsin. Any ideas? Thanks
Sent from my SCH-R530U using Tapatalk
War Wagon
Terry, MT
I'm not familiar with your area, but are there any local shops that specialize in diesel pickups? Your Ford dealer won't likely install any aftermarket products such as a EGR delete. The best fix for your 6.0L is a independent shop that will install the aftermarket fixes for the 6.0L. I work on them locally, but I can't really help you out as I'm located in MT.
NJKen
is a daddy!
Central NJ
If you would consider using bulletproof diesel (I have and I would recommend them) they have a installing dealer network and just might have someone in your area.
Ken
lewisstevey7
