8seconds
Looking to Modify
As the title states, I need information on how to pull the oil pan from a 1991 7.3 idi. I have went by the Haynes manual with no success. Engine has been jacked up and resting against the underneath side of the body. Manual does not state anything about removing the oil pump and pick up tube, but I beleive that this would be the only way to get it out.
Also what is the proper oil pressure for this motor at 2000 rpm, mine has shown about 37 lbs by the after-market pressure gauge, I added after the turbo oil feed.
