tbrumm
Caution: The following idea has not been tested, but in my best estimate SHOULD work ok....
If you have to remove your IP gear housing, do this... Bar the engine over until you can insert the allen wrench in the fuel screw adjustment hole. Loosen all the lines, and then you should be able to unbolt the gear cover housing, using the allen wrench as a sort of retaining mechanism to lock the IP shaft/gear in place. Additionally, longer than correct lenght bolts could be threaded into the IP gear access cover/oil fill and snugged enough to hold the gear tight against the IP shaft. DO NOT OVERTIGHTEN. I'm talking a very small amount of tension here.... Assuming that the rest of the gear train doesn't move while you have the pump off... when you drop it back on, timing should be perfectly preserved.
Thanks for posting that, Mel. My timing gear cover has had a small leak forever, but it is the only leak on the motor and drives me crazy. I was hoping to live with it until I buy my baby moose, but that will be a while yet as the truck hasn't turned 70,000 yet. If I understand correctly, you are talking about the two bolts that hold the front access cover on the gear cover and those need to be longer to press lightly on the gear itself. So these longer bolts are just to keep the gear cover itself postioned properly so it will "move" along with the IP and gear when lifted up enough to reseal under the gear cover?? Thanks again for posting this procedure to help deal with a simple oil leak that is not so simple. Todd
