my truck is screwed help
onus
Vernon, CT
I replaced my fuel pump thinking that was the problem. Fuel filter is only 2 months old. Truck runs a little than just dies chuggs.
Fuel shutoff solonoied? Ip is only 3 years old.
Seems to run fine in the morning and my entire way to college this morning.
onus
Vernon, CT
I don't see any air intrusion problems. The fuel is just under half a tank. I know my pickup shower-head is broke but at this fuel level it is never a problem.
Some more back story. I drove it over a half hour this morning at highway speeds no problem, after it sitting over night. Its when i try to leave college that it acts up.
IP is 25,000 miles old.
Dsl_Dog_Treat
Decatur,MI
If the shower head is known broken, I'd suspect chunks of it getting lodged up into the FSV restricting fuel delivery. May want to check to see what your fuel output volume is doing.
onus
Vernon, CT
Nothing getting lodged as far as i know. Though I'm sure it would be good to check at some point.
Did some testing. It is the fss. I'll be getting a new one. Pour water on it and the truck runs like a top. When it heats up again runs like crap.
flareside_thun
Reviving The General Tao
Tavares, Florida
That problem is not the FSS, those symptoms are indicative of a bad injection pump. 25k miles or not, you're due for another....
Geez, from the thread heading, I thought the truck got rear ended by a Chevy or Dodge , like Dodge it or Ram it. Glad it's only an IP problem. Throw a gallon of ATF in the tank, see if that helps.
onus
Vernon, CT
I'll try that. I don't really look forward to having to replace the ip already.
OK, HOLD ON HERE! Something doesn't check out. Let's examine the facts that you have presented.
Runs fine when it runs.
Fails to start when left OVERNIGHT.
You solve this problem by pouring water on the IP.
So lets see, your pouring cool water on a cool IP. Is this correct? Because before you went down this road, it sounded to me like a typical air intrusion problem. Which, by the way guys, air intrustion comes from leaky return lines, not air coming in with the fuel. When that happens, it runs like crap ALL the time.
So something is being left out here. Let's find out what it is?
justinray
Contributor
Cleveland, Tx
Do you try to crank it, then pour water on the ip, then crank again? This could still be air intrusion, you'd just be fooling yourself by pouring water on the IP, Also if this is the case, it could be what mine did, one of the wires from the solenoid to the GP relay was *****'d and I had to 'click' the key 2-3 times to start it.
Black dawg
sw mt
please describe your trucks symptoms in order from first start of the day.
jorge140
