Well for starters it really hasn't been just one weekends project, but basically it's almost the only time when i have a chance to do anything.
Before i start writing anything i have to use this opportunity to thank Agnem and of cource sle2115 who provided a core for Mel to work with. I know i live almost half way across the world in your point of view, but these guys did a great job to made all possible, so thanks again .
So like i wrote i had a little project to make some little service to my truck. It has done about 149 000 miles now and all started when i noticed that some injectors were shot. So i ordered from Mel a set of injectors and a MOOSE pump. I figured while i'm doing the service it's the same that i'll take the turbo off as well and have it serviced and put the ATS-upgrade parts to it. When almost everything was away from the valve covers i also changed the gasgets and that was really a PITA, because there wasn't too much room to deal with. This was the first time that i have taken these parts from these engines, so you can guess that it wasn't the easiest job especially the injection pump, but now it doesn't feel that complicated anymore and ip was much more easier than i thought it would be, so i guess saying live and learn is true.
So this was the starting overview, dirt almost everywhere and it felt like a huge project.
For a big handed these turbo pedestial bolts aren't very fun to take off
Here's a little cleaned up valve cover and how things looked inside of it
Then one day a guy from fedex brought a package from Mel and it contained some goodies
Turbo comparison and after rebuild. Turbo wasn't in bad condition, but bearings were changed just so that i don't have to take it off in any time soon.
Old G-code injectors and new Delphi BB-code, i think those injectors in a pic were ok, but from cylinders #1 and #8 injectors were totally shot and probably have leaked pretty bad. I haven't had a chance to take them to some shop where i could see just how bad they were.
Injectors and return line kit installed
Now things are at this stage. Yesterday i got a first smoke with the new pump etc. Few cranks to bleed the system and after bleeding turned the ignition key and it started almost immediately at first start .
Now i'm only waiting the turbo grommet. The older grommet is fine other that few cracks on top of it. It might go for a few years, but i wouldn't want take everything off just because the old grommet is falling apart...
I'll give you guys a comment of how my truck is running after i'll get the turbo on again and can drive it. You can probably guess that it feels like forever, when you are waiting for a test drive...
- kpj
- kpj
