bronco78idi
I have been building a 6.9 IDI for the past year and half. The motor is almost ready to be put together. I am going to video my teardown and rebuild. I have a YouTube Bronco IDI where I am going to start the complete teardown and rebuild. I will post info and picture as well here. I will have as much detail as I can on my build. I am building this for me. What is it going to be used for you ask. Whatever I need at the time I need it. I am not a rock crawler guy, but I have done it when I needed to, I am not a mud slinger, but I sling mud when needed to. I use my Bronco as a tool and I take care of my tools. I have been in Wyoming in the middle of winter hunting, Colorado, Idaho, and Rubicon Trail, Beaches, Baja California Dunes and the salt flats of Utah. I have always felt the Bronco is a Great off-road vehicle. I am the first to admit it’s not a Jeep; But a Jeep is not in the Bronco Class!
What I have done to the engine so far.
Block
Line Board
Decked
Balanced Rotating
Cryo Rods, Piston Pins and Pistons (milled piston for balanced deck height prior to coatings)
Tri-Coated Pistons (seal Power)
Dry Film coated Main and Rod Bearings (Clevite 77)
Crank Nitrided
Total Seal Rings
R & D Stage 1 Cam
Heads
New Valves –Ceramic coated face
Intake Valves (Perfect Circle)
Exhaust Valve (Stellite)
Comp Cam 910 Springs
4 angle Valve grind
Harland Sharp Custom Roller Rockers
ARP Head Stud
Misc.
Victor Rienz Complete gasket set
R & D Custom Intake
Waiting for the bearings to come back from being coated
Block
Line Board
Decked
Balanced Rotating
Crank Nitrided
Total Seal Rings
R & D Stage 1 Cam
Heads
4 angle Valve grind
ARP Head Stud
Misc.
R & D Custom Intake
