There's really no tell tale signs of future failures.
Just give it a good looking over.
Thanks, that's kind of what I figured. Is 228000 pretty high mileage for a PSD, or not so much? Worth sending in an oil sample?
Is there some kind of glossary anywhere online for the OBS PSD? Curious about all the abbreviations.
I figure this thing is worth 2500 - 3000 bucks to me, it has a pto dump, zf 5 speed, and I would be maxing out a 1 ton with the work I do.
I like the hydroboost brakes and the 15000 gvwr of the super duty.
I would jump on a OBS Super Duty with an IDI, but the PSD seem much more common in the super duty's. The extra power ($$$$) will be nice.
Is the lift pump in the same location as an IDI? What about the HPOP? I am guessing this stands for high pressure oil pump?
Any easy way to check oil and fuel pressure? What kind of readings am I looking for @ idle, going down the road, WOT, ...?
The guy said he just replaced the oil cooler and that fixed the low oil pressure problems it was having.... Sounds like it starts and runs good, no smoke or excessive blowby.
