69oiler
I don't feel tardy
well thanks to help from Nick and Russ i now have ditched the stock exhaust system for a new stainless 4" system with a straight thru muffler.
just got it today. first impressions are, better throttle response and way less turbo lag. the sound is OK, lots of turbo whistle. there is a bit of a drone but it's not bad at all, sounds as good as any PSD i've heard. the off-idle whistle from the exhaust sounds sweet.
i havent run a full tank thru it but i did fill up on my way home ($3.23 couldn't pass it up) and then topped off when i got home ($3.54). the 4 gallon top-off showed 15.8 mpg
definitely an improvement over the 12 i was getting regularly with the old cat and muffler intact. i'm excited to see the improvements over the next few fillups.
i also got new GPs installed and new front axle joints. so now everything on the SD is working again.
special thanks to Nick for a fair deal on the job and to Russ for all his help. i owe you one.
