Hypermax has told board members here that you can run it at 1250*F with a turbo all day long, BUT that presumes everything is working perfectly, what if some of your oil cooling jets are slightly plugged? How about if the oil pump is not pumpoing quite as strong these days as it used to, worse what if your pyro is reading 25-50 degrees F lower than it should.... personally I like a little fudge factor so 1000-1100 would be the highest I'd ever want to see it mounted pre turbo. I hear that NA stock engines were calibrated to max out around 1150*F so 1150-1200 sounds like a good max number maybe 1100 with the probe right in the manifold or in the crossover within 3-4" of the manifold. But that's just me some folks like to live on the edge and have to watch the pyro like a hawk, I don't.
