Max and average boost for factory turbo
Brutis
Work in Progress
Niagara, Wisconsin
Hey everyone,
Just trying to pin down some information. I am wondering what boost numbers are average and/or max for a factory turbo. It was making at best 4psi at WOT, but I can see definate signs of exhaust leaks where the y-pipe joins to the up pipe. I am hoping to get my turbo rebuilt and back on the truck, but if it can't make at least 8psi (to operate my Water/**** injection) I may look into other options.
My truck is not running currently, so I thought I might as well map out my plan for repair/upgrade.
Thanks in advance!
FordGuy100
Silverton, OR
My turbo which is the same except different exhaust housing and downpipe would make 8-9psi depending on outside temperature. Without the wastegate functioning I can peg my 15 psi boost gauge real easy
rjjp
Needs to go test
Clare, Mi
I have the same turbo, as stated above it will go over 15 easily (adjusted waste gate too far, and then adjusted fuel) I have 2-3 at 60 and about 4 at 70 with the cruise on on flat ground.
1994IDI
Destin, FL
I have my pump increased about 2 flats, and see 5 psi on flat ground at 60. 6-7 psi at 70 and above on flat ground. 8 psi is the most I've seen on the gauge, on a slight grade with about 500 lbs in the bed at 75 mph. Factory turbo, my wastegate has not been adjusted.
sootman73
Wauseon, OH
I have my wastegate tied shut and pump maxxed. i can easily hit 15(well could but i think i developed an exhaust leak from the higher drive pressures) now i'm running about 13 but i gotta look for that leak and prob just do some adjusting to the crossover pipe fitment.
