LUCKY_LARUE60
your transfer case is hard to shift because the shift lever pivot is probablly all rusted up, my 90 was the same way. when i changed trannys i was surprised at how much rust and crap was inside the pivot joint.... try getting under there and cleaning it up. i was really surprised how easily it ws to shift into 4wd after i got everything cleaned and lubed up.
On my old 93 I had the same problem with the T-Case not being able to get into and out of 4X4. I took gear oil and oiled the shifter and worked it untill it freed up. Just take the boot loose from the floor and pour the gear oil on the shifter.
Now all I have to do is turn a knob
Jim
