Magnafluxing Heads - Where to Check?
bulletpruf
San Antonio, TX
Fellas - I'm magnafluxing a pair of heads that I pulled off a 94 7.3 IDI-T. The pre-cups are cracked, of course, but what about the rest of the head? Are there any areas that I need to focus on besides just checking the surface of the chambers?
Thanks,
Scott
Booyah45828
Ohio
Precup cracking, so long as it doesn't extend past the fire ring, is okay. Any crack in the head is no good. Check the normal areas like between valves, valves to the pre cup chamber, and valves to bolt holes.
bulletpruf
San Antonio, TX
All the pre-cups are cracked, a few past the fire ring. I have another set of heads from a low-mileage NA 7.3 that I need to remove and check as well. Hope these have nice pre-cups and no cracks. Thanks
