firehawk
I finally pulled the tranny this weekend, and the disc looks suspect. It was obviously slipping, only about half the disc seemed to be making contact. When you look at the disc on edge, the metal that the friction material is riveted to is bent, much like if was trying to be a spring. I have never seen this in a disc, so I imagine that is the problem. Anyone else have one to check out or remember looking at theirs?
The flywheel and pressure plate look fine, and the springs on the PP were flat and even when installed. I am going to buy just a disc, as this setup had less then 10k miles on it.
