The machine shop I am using is a Great guy, but I think this is his first real diesel build.
That scares me a bit. These are NOT just large versions of a small block Chevy and if the machine work isn't done properly, it could ruin your heads/block and your build. If he doesn't know about these IDI's and hasn't done them before, I'd honestly look else where for machine work. It is a very vital part of rebuilding these IDI's correctly........ and if done wrong, can be a nightmare.
As far as parts and their cost....... here is the list of stuff I did/used on my 6.9 rebuild.
The final tally of parts and their cost, here's the list (it's a little scarey):
Machine work and installation of new cam bearings $1100 ($220 of that was balancing work)
Gasket set and valley pan (Victor Rienz) $250
Clevite 77 rod and main bearings $314.25
Mahle reduced compression pistons with rings, pins, clips $550
"typ4" cam $200
New Ford lifters $90 (eBay find)
Intake vavles (Perfect Circle) $75
Exhaust valves (EngineTech Stelitte face) $105
Comp cam 910 springs $81
Rear main seal with repair sleeve $42
Head work (had to be redone, 1st shop didn't do what they said they did) $410.26
ARP head studs $215
7.3 PSD intercooler $200
Intake hat $66
Intercooler piping/boots $194
Moose pump $689
Moose injectors $1085
Water pump (new Ford) $95
Head dowels $12.50
New 7.3 rockers (Melling) $95.92
Rodney Red Radiator $750
Total = $6619.67
Heath
