JMWRIGHT335
That is correct, Yes I have checked the EBPV, sensor reading are above and the valve itself is free by hand and fully functioning electronically.
Don't know about the 97's IPR, but the 99 and up have a tin nut that holds the solenoid coil, if that has backed off then your CP will be low. I get about 14 - 15 boost on my 99.5 at WOT, peddle to the metal, about 25-30 WOT pulling a 11500 lb 5er on acceleration.
Replaced oil, oil filter, and fuel filter with OEM Motorcraft parts then performed BB mod and cleaned fuel rpessure regulator screen which was blacked out. Acceleration is "Better" but still falls on its face at WOT.
RSRACE, How did you come to this realization of faulty injector o-rings? I assume you needed to remove the injectors?
Nope. He hasn't been back since 2013.
You having the same problem?
