JMWRIGHT335
Hey all, my 97 is completely stock shy of a full exhaust 3 inch down pipe and 5 inch out the back no cat no muffler and a clean new filter and A BRAND NEW TURBO, also a brand new PCM. I bought the truck as she sits with 100550 miles on and clean as a whistle. I'm a technician and I have a snap on Solus Ultra so I can monitor everything the truck sees. My complaint is the truck accelerates normal as long I stay no more than about 1/4 throttle if I go WOT the truck drops gears as it should and the turbo screams but I go no where. Now I know everyone will just go to trans shifting but this isn't the problem as the rpms don't rise, they rise initially when I downshift but even in direct drive my rpms rise slowly as the truck slowly accelerates. Now I have no faults at all, except for P1111 for system pass.
I have verified correct operation of the EBPV and it moves free
I measured boost at the map sensor and had a max reading of 8psi WOT
I then under WOT manually applied vacuum to the map sensor and then the truck made no additional power, shook a bit and made no smoke.
I then disconnected the map and ran it that way with no change.
The truck has never smoked any color.
As I said before this is a brand new turbo so there is no play in the wheels
I have no soot build up anywhere its clean as a whistle under there.
Ran a cylinder contribution test: PASS
Buzz test: All 8 injectors sound the same... PASS
Solus offers a expected range that everything should be in and every monitor is 100% in
line with what is expected.
Fuel pressure at idle is 50-60 psi bouncing between the 2
Fuel pressure at WOT seizes between 30-60 psi but at higher RPM`s it levels out to 50-60
Next i smoked the intake with an actual smoke machine and found 0 leaks in the intake, through the map sensor hose, the up-pipes everything is solid...
alldata says at 2500-3000 RPM while t-ed in on map sensor line. " If boost pressure us 15.5 (90kPa) or more, boost level is ok. So theres definantly something peculiar happening im almost half of that.
Any other ideas? Of what to check, im running low on ideas.
Thank you all.
Thank you all.
