loping
Randy Bush
Great Falls, Mt
The last couple of morning being it has gotten cold, 29 degrees, my e99 PSD lopes for just a little bit when I start it,what causes this? Smooths right out after maybe 30 sec or so. Thanks
greenskeeper
PA
what oil are you using? 5w-40 (I run rotella) does wonders for the HPO system
DaveBen
Ukiah, Ca
5-40 oil will stop the lopes. I had this happen with my 2004 6.0l. It started to lope when it got cold. I changed oil and the lopes stopped.
DaveBen
Ukiah, Ca
Dirty oil/dirty injectors is what does it, hotshot's stiction eliminator usually cleans it up.
Not always. At least on a 2004 6.0. I had made my first winter when I found out about 15-40 and loping. I had maybe 8,000 miles on it when I switched.
Imo, unless running a bypass filter or very high quality synthetic, 8k for a 6.0 is really pushing it. Just new oil would make it run better. The 6.0's have higher fuel dilution levels than a 7.3. (Not to mention comparing 6.0 to 7.3 injectors is apples to oranges, with the design differences in the spool valve)
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
Dave bought his truck new off the lot. I believe he is saying the truck only had 8000 miles on it total when he started using 5-40, not that he had 8000 on the oil change.
DaveBen
Ukiah, Ca
Yes Scott, 8,000 total miles since new. I would never go that far, on my truck, for oil change.
