Look what Gale just posted!!!
I was on YouTube going thought all my subscribed channels, and low and behold, look what Gale Banks just posted:
THIS THING IS AWESOME!!!! My favorite body style and colors!!!!!!
Before you watch, go get some napkins to wipe up the drool!!!!!
Jcsheriff
Hondo Texas
I’m left speechless, I was feeling nostalgic and envious at the same time. Thanks for the inspirational video.
Clb
Another old truck
nannyfornia
Hope he is reproducing the old setups...
Rusgo
US
IDIs are beasts. Among the coolest things humans ever made. Mechanically controlled precision explosions
Like if you combined a fine Swiss watch with a Molotov Cocktail. Then throw it inside a tractor to get moving
My first love was a big block Chevy, but always disappointed I had to add computers for multiport fuel injection. Always dreams about mechanically controlling that setup. Then discovered thay IDI was all that already in big block form
Then 420 cubic inches also being 6.9 liters?! Beavis and butthead would be proud
miles1400
Macungie PA
the owners instagram name is @ch_classics he uses that truck as a mobile detailing rig
chris142
SoCal
No specs? No sound of the truck going down the road and they should fix the glow plugs properly. Lame!
Honestly, on the factory 6.9 System, switching to a push button is the "proper" fix. The factory 6.9 Controller has a bad habit of failing "on" and burning up the glow plugs. So most owners just switch to a push button, to supply +12 volts to the relay on the fender to activated the glow plugs.
Or, if you want a controller, then switching to the 7.3 style controller (which your 87 would have factory, 87 was the only year) would be a better choice. The 7.3 controller will fail "off" and not destroy the plugs.
Some, including me, will even put a push button on the 7.3 controller. Providing a ground to the relay to be able to override the controller if necessary.
Stu Bailey
Idaho
So if done right, is there really any harm to a 6.9 if you put a banks turbo on it? This video just convinced me that I need one haha
Rusgo
US
I love my 6.9 controller. Tucked away by the firewall out of the way. Simple. Has worked perfect for years. Truck starts fast everytime.
You saying it's just a ticking time bomb?! Damn. It might have to go now
If by saying "if it's done right" you mean adding studs, then the answer is "no". There's no more harm done to a 6.9 than to a 7.3 by adding a turbo. Just remember that, due to the smaller diameter head bolts/studs, a 6.9 can't handle the same amount of boost pressure that a 7.3 can. People have probably been putting turbos on their 6.9s since 1983.
oregon96psd
Kuna, ID
Ghetto glow plug system, rigged starter solenoid, craptastic shell on the back.........c+ at best lol
Well, the factory location for the 7.3 Controller, is on the back of the intake, by the firewall. Are you sure it's the 6.9 style you have? The 6.9 controller threads into the back of the drivers side head. The 7.3 controller is bolted to the intake, just beside where a 6.9 one would be located. The only other location that I have seen, factory anyway, is on the valve cover on a factory turbo engine.
Is the 6.9 Controller a "ticking time bomb", not necessarily, but know, if it does fail, they normally fail in the on position, and will cook the plugs to death. However, you would also see it happening, as the Wait To Start light would be on when it shouldn't be.... if you notice it, and are able to disconnect the purple wire from the relay in the fender, you might be able to save the plugs.
JU57US
