JSVD
while doing a headgasket, i put in a cam grind. Upon startup I had some minimal valve piston contact.
The lifters looked fine, and were not pumped up when installed.
I have them back out, and when i try to pump them, they don't move at all. Is this normal? No work was done to the lifters. All the lifters were installed in the same location they were removed.
I have a new set of lifters coming, but i need to install these to move the truck to a new spot to work on it.
