im trying to help my buddy find a good deal on a lift pump for a 96 12 valve, localy there around $200 he has a #5 fuel plate does he need a upgraded pump or will a stock one do? who has them for cheap? thanks -russ
Hi Russ,
The lift pump is not an issue until you get into the 24V.
I'm not sure how much they should be. I'll find
out soon as I need to buy one myself for a '94 12V.
I guess they'd be more at Dodge and Cummins.
Did you check out places like BD, and Piers?
They're both up here, you must have some
places closer to you, or, get it shipped.
it seems that napa is the best deal at $154, we're pretty sure the spring in this pump is going out because its clicking a lot, my buddy seems convinced that he has a supply problem because he isnt getting any smoke and has less power than he thinks he should have with the #5 plate
