Lift pump changing fuel mileage
Shadetreemechanic
Monteagle, TN
The guy that drives my 85 f-350 says he has moved from 14 to 15.5 mpg in the month since I replaced a failed lift pump. It was mechanical before and is mechanical now. Its a delivery truck and gets about 500 miles per week on the same route.
Any theories as to why the mileage would change? I'm confused.:dunno
The only reason for that is that I can think of, would be that the engine is running more efficiently, no air to the injectors.
firehawk
Dallas, Tx
Drag on the motor from the pump. I am always amazed how a little friction can affect efficiencies.
justinray
Contributor
Cleveland, Tx
If the previous pump wasn't pushing adecquate pressure, that would advance the timing back and forth when it would surge. Iirc, when I checked, more pressure retards timing and less advances it. Seems like it would be the other way, but I believe that's what I found.
bob123456789
