lets talk intakes
res0wc18
Everett,Wa
all right guys for the 1997 stroker, which intake is best and why?
Or is the stock system with a high flow filter the best because it ducts the cold "ram" Air?
Mike
Stroker
Cora
Open paper element hands down the best air flow and best filtration you can achieve.
do a search for "BHAF" and you'll find many homebuilt setups that cost a fraction of the fancy kits.
Mike
Stroker
Cora
so like the tymar, and not the synthetics like the kn setup etc?
Why?
As stated, you'll get better airflow and better filtration with a paper element over anything else out there, period.
The bench flow tests have been done numerous times, filtration and flow with a paper element is superior to the "reusable" element type.
With the reusable type , filtration is at its best when it is nearly 100% plugged at which point you take it out, wash it in detergent and re-oil it which puts it back to its most efficient flow but least efficient filtration.
res0wc18
Everett,Wa
but what are we suppose to do with the air temp sensor when we do a tymar type intake?
res0wc18
Everett,Wa
that search doesnt work worth nothing. i searched for tymar intake and it couldnt find that either.
res0wc18
Everett,Wa
by the way towcat the woman is gorgeous in your avatar.
How do you put pics in there?
childildersj76
Haltom City, Tx
the problem with open air setup is as opposed to factory in 94-97 is the intake temperature is from under the hood with no intercooler to add density to the air
childildersj76
Haltom City, Tx
if you have the full banks powerpack it should come with an intake system they put alot of research into everything they do, and told me the only restriction in the 94-97 stock intake was the stock tubing. But I'm not saying it can't be improved.
Mike
Stroker
Cora
All you do with the IAT sensor is zip tie it to the inner fender.
Vinceslamer
