let the upgrades begin
rustyescott
waco tx
well after a year of gathering parts have finily started to do the following upgrades. elec vac pump, a/c mod, hydroboost, power captains seats, cooleant filter, rebuild oil cooler, new water pump,move elec lift pump and filter housing.
Sounds awesome man, I'm looking forward to lots of pictures, keep us updated!
88beast
pa
-cuss wheres the pictures!!!!!!!!!!!!!!!!!!
1466IH
waterloo, il
Whats the elec vac pump i havent heard of that yet what is wrong with the engine driven
jada64
Boost Junky
Bay City, MI
Im interested in the seats your doing. My front seat is desperately needing replacement. Pass side is jammed all the way back and the previous owner had to of weighed a few hundred more than I.
ok tried to upload pics kept having problems
Get a Photobucket account
Create an album pertaining to what you are doing
Load pics to album
from album copy the IMG links from picture and paste them into thread
You can post a max of 15 images in a thread inclusive of emoticons
JM2CW
Oh, it's the only way I roll for simplcity.
rustyescott
waco tx
got hydrobost plumbed today new housing on power sterring pump.fuel pump block plate on.new temp guage wired in.
opusd2
BFE, WI
I always wanted to try going with an electric Vac pump, the ones for SDs aren't all that expensive when compared to others. But I should probably just get the truck running better first. ;-)
Oog
Southern Illinois.
Fellas, look at turbocharged german cars. Most Vulvas (volvos) come turbocharged with a vac pump. They usuallu wind up in the yard of junk due to expensive repais.
Fin
racin460
York PA
what do you do with the factory vac pump, I mean how do you eliminate it.i thought about doing that my self but haven't thought of a good way to remove the mechanical vac pump.
Oog
Southern Illinois.
You run a hose inside hooked to a hollowed out pickle.
Presto!
Petroleum powered ***** pumping device!
Medrunk
/fin
rustyescott
waco tx
3 bolts and it's gone plus need shorter belt.and here is the part # for the belt i'm using.goodyear 4061080 under 11.00 on rockauto.
