tractorman86
So I was on my way to work in laughlin this afternoon I get to Nothing, az and ironically my truck has nothing. I had the cruise set at 75 and started to loose speed, no big deal it has turned off the cruise on it's own before, so I try to kick her in the guts...no go, I look at the gauges and all is normal except the tach falls to zero. I did some checking and I've got good voltage, my fuel pump is operating correctly, after about a 20second crank it reads normal oil pressure, but I pulled the IIRC icp sensor (top front of the passenger side valve cover) and had a guy crank it for roughly 3 seconds and only got a dribble of oil. My guess is hpop, but with no access to a scanner I am sort of swinging blind, any ideas?
