johneich
John, 1983 F250
I think you take out or put in shims to adjust pop pressure, can anybody expand on that? I just bought an injector tester, if it is shims where can they be bought?
John
John
You better have a 0 to 1" micrometers to measure the thickness of the shims. IIRC the shims are from .003 to .010. TYP4 can probably tell you how much pressure increase each size shim will give.
The closer you get them to pop at the better the engine runs because of the injection timing.... Figure an injector poping at 1500 lbs and the rest at 1800 lbs... The low injector will be advanced compared to the higher poping injectors. Just think if that low injector was the number one cylinder your using to time the engine.....
Wow, you just made me really think... maybe I need to check my timing on #1 and #4 cyls to make sure it is the same...
From: http://www.thedieselstop.com/contents/getitems.php3?6.9L Injectors
"When doing a pop test, there are four things you want to look for. The first is the pressure at which the injector releases the fuel.
Is there a supplier for .001" injector shims?
