Knocking engine
Rdnck84_03
Kansas
@KansasIDI I'm not sure what all you have done so far but if I were trying to diagnose it. I would start with a compression check. Depending on what that shows pull the valve covers and see whats going on with the valve train.
James
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
What stuff do I need to do a compression test on an IDI? I’ve read to use the glow plug holes, but I’m getting contradicting info on what jit to use etc
KansasIDI
Wilsey, KS
I do it through the glow plugs. If you YouTube how to compression test a 7.3 idi with a harbor freight kit I have a video on YouTube. Let me know if you have any questions.
Do you have the link I can’t find the video
KansasIDI
Wilsey, KS
So I went to go start my Ford to move it, and it started up and ran for a little bit, but soon died like someone had turned off the key. Was getting power to the shut off solenoid, but I figured it must’ve just been dumped up. I had that issue right when I got the truck. I took the top of the injection pump off and turns out that it is half full of diesel and the other half full of metal shavings. That might be my issue.
Yikes.
Well at least you're in the right place to find a good replacement.
Could be the pump isn't capable of supplying sufficient pressure to the cylinder.
KansasIDI
Wilsey, KS
Turns out my injection pump has a hard spot that when you rotate through it it makes kind of Beck, grinding, chuffing noise with a click
Nanohawk
