I had a problem similar to that on a mitsubishi diesel once. There was a oil drainback problem that caused oil to fill the valve cover until it would go out the crank case vent hose and get sucked in by the turbo inlet.
When driving the feeling was of a runaway engine. It would start to crackle louder and spool up on its own accord until enough oil was sucked out that it would come back down again. Threw tones of smoke too....and not all blue either.
This is why I asked if the engine is using large amounts of oil that can be observed on the dipstick after a drive involving a runaway event like this.
To prove things once and for all to myself with that particular engine, I routed the hose to an oil jug under the hood. Sure enough, under the same conditions, the engine ran fine this time, but when I pulled over there was over a liter of oil in the jug that would have otherwise been ingested by the engine.
I would check your CDR valve or even rig a temporary RDT into a jug like what I did to see if oil injestion is causing your problem because if it starts and idles easily, I don't see this being caused by something in the fuel system unless you have a major air leak (but that would likely cause hard starting).
